Focuser Knobs - Rubber Grip Issues
Started by IGastaldo, 09/22/2006 03:50PM
Posted 09/22/2006 03:50PM | Edited 09/22/2006 03:51PM Opening Post
This will be the third time that I'm going through this... :S
The Rubber grip band, that goes around the Focuser Knob, keeps breaking on my ED-80... not sure if anybody else has seen/had this...
Is there any other product out there to replace these Knobs with? (NOTE: I know there are many products out there to replace other focusers knobs, but have not seen any to replace the ones that come with the ED series of scopes...)
Thanks for your attention, and clear skies! 8)
Posted 09/22/2006 04:54PM #1
Hi Ivan,
I use a rubber chair leg guard, the kind that slips over the end. They are available in many diameters. I then cut them off to fit the knobs. I do this for the cold as my fingers get very cold touching the metal of the focuser. It also increases the diameter thus making it a finer adjustment.
fblue's attachment for post 107507
Posted 09/22/2006 06:32PM #2
Seems to be a problem with ED-80's. After mine died, everytime I got a flat tire on one of my bikes, I would cut a section out of the inner tube and give it a try.
700c x 23 tubes are too small
26 x 2.0 are too big
If I remember correctly, something around 26 x 1.25's are about right but it takes two layers...
Works for me.
Another solution is to use some O-rings
jon
Posted 09/22/2006 10:40PM #3
My ED80 did the same thing. Orion is well aware of the problem and will send you replacement knobs for free. Just give them a call. -Kurt Horsley
Posted 09/23/2006 03:19PM #4
I've owned lots of scopes and bino's that use these rubber grips - happens to them all eventually. The rubber both dries out as well as UV degradation...As nice as they look and feel, I almost always replace them with machined wheels if possible. Although I think Floyds idea is quite a good compromise!
This was one of the reasons I liked the WO 66-80mm scopes over most of the other clones which use these rubber grips.
Posted 09/23/2006 03:46PM #5
Ozone causes rubber to degrade. Also, the solvent evaporates in the rubber. Those of us too cheap to spend $5 on new windshield wiper blades wipe them down with a solvent like Berrymans or whatever. The rubber absorbs the solvent buying you some time. This is done about every 4-6 months. This explains why rubber stored in cases or dark places still corrodes.
Orion should move to a polymer or silicone based replacement.
Corrosion 101
Posted 09/25/2006 02:02AM #6
Mr. Gastaldo:
I thinks these will fit the focuser posts on the 80ED crayford.
Regards,
Jim
http://www.scopestuff.com/ss_fkcx.htm
