I read a previous thread somewhere that stated an ortho or maybe kellner is good for use with a reflector. I assume good ep's (naglers and the like) are still not a bad way to go. I want to get a 12mm Brandon or maybe a used nagler. I purchased the Orion 8" EQ and it is pretty inexpensive so I have a couple hundred left to get a good ep for use with a refractor and reflector. Both are fast scopes, f/5 and f/5.6. Suggestions for ep's under $200.
Good eyepiece for 8" reflector?
Started by thoth11, 07/30/2003 04:37AM
Posted 07/30/2003 04:37AM
Opening Post
Posted 07/30/2003 05:11AM
#1
Hard to answer without knowing exactly what you have, but you can pick up many of the old Naglers for less than $200 (4.8mm, 7mm, 9mm) right here on Astromart. The Meade 8.8mm and 14mm UWAs are also outstanding.
Kellners are OK in longer focal lengths, but often have ghost reflections. If you were willing to live with ghosts, Orion's complete Expanse set can be had for under $200 (6mm, 9mm, 15mm, 20mm with 66* fields).
Funding Member
Sponsors
- Desert Sky Astro Products
- Anacortes Telescope
- SellTelescopes.com
- CarbonScopeTubes LLC
- kwtelescope
- astronomy-shoppe
- Matsumoto Company
- Vernonscope
- Astromart Customer Service
- APM-Telescopes
- AstroMart LLC
- RemoteSkies.net
- FocusKnobs
- BW
- BBLABS LLC
- Waite Research
- OMI OPTICS USA LLC
View all sponsors
