Help!! Meade SCT corrector
Started by lutton.7, 01/29/2004 12:02AM
Posted 01/29/2004 12:02AM Opening Post
I was out observing when I noticed it was snowing lightly. Without clouds!! I packed up quickly and got the scope home, but after the snow flakes melted there were some water drop spots.
I didn't think it would be a big deal and didn't mess with it. The spots were tiny and very few. BUT... after it had set a few days, it looks like there is corrosion or some type of acidic marks on the corrector!!! I count about 20 of these spread around the corrector.
Has anyone had these spots before and do they clean off ok? I've never had the corrector off because the scope has performed wonderfully and I didn't feel the need to clean it.
Any suggestions? If it is some type of acid from the snow (slight acid rain??) or possibly salt a deposit I'd like to clean it off.
** caution, the image is a bit large on the following page, but it gets difficult to see if I resize it too much smaller**
Posted 01/29/2004 12:07AM #1
Ok... pic didn't load. I'll try again...
lutton.7's attachment for post 75711
Posted 01/29/2004 12:53AM #2
Probably just things that were suspended in the snow and then deposited when it dried.
I would not worry too much. It will not effect veiwing I would not think.
You could take a Q-tip and just dap at one spot with a little lens cleaning solution and see if it comes off.
I mean just dab do not rub and only one that is in a spot that won't be a problem if you leave a tiny smear!!!!!
If it comes off, then you could either clean it or have it cleaned professionally.
Please understand that cleaning a corrector plate is not for the faint hearted and it can become a real nightmare if done improperly.
I am only implying that you try one little spot to figure out if it is permanent or can be cleaned.
Floyd
