Ralph Ford
M31 with Redcat 51
Help needed- DS16 mounting/ C14 OTA
Started by astroskywatcher, 05/18/2013 02:59PM
Posted 05/18/2013 02:59PM Opening Post
Help ... I'm trying to mount my '74 classic C14 to a DS16 mounting ... Seller of mounting trying to help me w either a saddle/dovetail OR saddle/rings arrangement ...
WHAT/ HOW can I mount my OTA to this DS16 mounting??
Posted 05/20/2013 08:32PM #1
Alexander,
Ask the seller if the existing saddle can be unbolted from the mount. If so, then a new plate can be easily made to fit the bolt pattern of the mount as well as whatever rings you choose to use to mount the C14. Homeyer cradles are nice as are Parallax rings. Either company may be willing to fabricate the mounting plate to your specifications, too.
Posted 05/20/2013 08:47PM | Edited 05/20/2013 08:48PM #2
Hi Alexander, the DS-16 saddle plate is thick aluminum and can be drilled then the holes tapped to fit a Losmandy "D" style saddle. From there you put the "D" style dovetail on the C-14 and away you go. ADM makes nice "D" style plates and saddles. I would contact ADM. If you aren't handy with a drill and taps, find someone close that can help with that part. It's pretty easy to do.
