Ruben Tommasi
Andromeda Galaxy (M31)
How Critical is Focuser Alignment ?
Started by samg74, 03/19/2004 12:46AM
Posted 03/19/2004 12:46AM Opening Post
For all the talk about mirrors and secondaries, how critical is it lining up the eyepiece ?
If it's off a degree or two, what's the expected effect ?
Posted 03/19/2004 12:52AM #1
You will lose a bit of illumination at the EP is the result. Possibly some other abberations as well, like coma.
I had one scope that the focuser was 1/4" over from centered, it had a much improved image when the focuser was aligned properly.
Floyd
Posted 03/19/2004 03:17AM #2
Normally misaligned focuser will cause visible misalignment in the rest of optical train, so that it gets fixed. Assuming that focuser alone somehow gets out of alignement in a previously aligned scope, it will take center of the eyepiece field out of the center of mirror's image. That will bring off-axis coma into the center of eyepiece field. How much of coma, depends on the amount of tilt of the focuser(t, in degrees), image hight above the tube(h, in mm) and mirror's f# (F), and it's given as coma wavefront error (in units of 550nm wavelength) with w=th/1.5F^3. For sideways shift (s, in mm) the coma error in the field center is 38s/F^3 (independent of the image hight).
It's good to note that identical pick wavefront error of coma results in lower average wavefront deformation than that of spherical aberration. A 1/4 wave of coma causes 1/22.6 wave RMS, while 1/4 wave of spherical aberration causes 1/13.4 wave RMS wavefront error. The proportion between the two is constant: any given coma wavefront error compares in effect to 41% smaller error caused by spherical aberration.
w=
Posted 03/19/2004 04:51PM #3
I would say that the expected effect is that you'll wonder if you could be getting better views if the focuser was aligned correctly. ;-)
I would advise that you go ahead and align the focuser. I've had a few scopes that had slightly mis-aligned focusers. Fixing it resulted in cleaner collimation, really nice star tests, and great views.
Doug
