I found a bug with the C925
Started by SunSpot51, 06/21/2004 05:09PM
Posted 06/21/2004 05:09PM Opening Post
Well...that got your attention!! I was installing a set of Bob's Knobs on Friday when to my surprise, in the tube assembly I found a dead june bug! It must have flown in when I had the eyepiece area uncovered to let heat out. I remember a while back seeing something flutter in the webcam while imaging the moon...thought it was a bird or moth but it went away and I forgot about it.
Anyway, I was wondering how I'd get the dead critter out. I didn't want to remove the corrector plate (I am totally NOT mechanical), and the thought of sending the OTA to Celestron at a price of shipping, and at least $100 to get it removed wasn't very inviting either. Time for radical action!! I found that the extender tube from my vacuum cleaner would just fit down the rear hole. I thought I'd give that a try. Sure enough, I turn the cleaner on and I hear a "click" sound of something being sucked into the vacuum cleaner. Looking into the OTA I found the june bug gone, as well as the various body parts that had already fallen off...in addition the inside of the tube assembly looked cleaner than I remember.
The best I can guess is the tube assembly is fairly air tight and when I turned on the vacuum it sucked the air out of the ta and took the june bug and anything else loose with it.
I'm not sure I'd suggest this on a regular basis, but like I mentioned...it was time to try something radical. grin
Paul Maxson
http://glory.gc.maricopa.edu/~pmaxson/index.htm
Paul Maxson
http://www.sunspot51.com
