Philip Imbrogno
Mirror cooling & Deformation, all you ever wanted
Started by fblue, 08/29/2006 05:53PM
Posted 08/29/2006 05:53PM Opening Post
http://home.hetnet.nl/~artm/atm/articles/cooling.html
This link contains a study of mirror cooling and deformation with no fans, one fan on rear and a fan on both sides of the mirror.
The study shows that a fan on both sides is much better than just one on the back and that the amount of deformation is greatly reduced.
Interesting read for those interested.
Posted 08/29/2006 10:02PM #1
Floyd:
A while back I made a "back of the envelope calcuation" that was quite similar, it showed that for an 8 inch diameter one inch thick mirror, a 1 degree C thermal gradient from one side to the other would cause something like a have wave deflection. I made the same assumptions and so this was also a spherical deformation.
As the link pointed this is not as bad as it sounds because it is spherical deformation superimposed on a parabola that is only slightly different from a sphere, if this were a scope like an SCT with spherical optics, the only difference would be a slight change in the position of the focal plane. Of course the thermal gradient will not be uniform or linear ...
Anyway, I exchanged Emails with Brian Greer on the subject. As you know Brian has been the one to do quite careful testing. I came away from that exchange with the belief that the thermal strain in the mirror is not the critical issue at all, rather it is the what I would term "the local seeing inside the scope" caused by the warm components including the mirror.
Posted 08/30/2006 01:22AM #2
I guess my question would relate to a closed tube 12" dob. What would the ideal fan number, placement be for such a scope. I see your single enclosed fan assembly. Is this your recommendation?
I Yam What I Yam!
Posted 08/30/2006 02:12PM #3
This can all be avoided with a quartz or ULE mirror.
Rolando
