John Greenlee
Before and after
need help
Started by alaric, 03/07/2007 04:11AM
Posted 03/07/2007 04:11AM Opening Post
hi all,
Sorry if I posted this in the wrongs spot, but I need some advice. I am think about buy a 10" dobb and was wondering if someone could give me some pro and cons of dobb scopes, I'm thinking about getting into astro photo will a dobb work for this?
thanks for the advice
doug
Posted 03/07/2007 04:17AM #1
Doug, just to make it simple, Dobs are NOT designed with Astrophotography in mind... they are mostly VISUAL scopes... (unless you mount them on a platform, then you might be able to do some photography)
What you need is a scope (reflector/refractor (depending on your budget & photography plans) mounted on a Heavy (if possible) Equatorial mount, motorized (to track the object) & maybe with GOTO too... (to find the object quicker)
I'm sure others will chime in... stay tuned!
Clear skies! 8)
Posted 03/07/2007 05:30AM #2
A Dob is not the best choice for photography, but makes a great visual instrument. 10" is a nice size that is mid sized in performance and transportability.
Photography is not a beginners game though and I would suggest that you do some visual work first. But if you really want to do photography, then you should think about an SCT or refractor on a Equatorial Mount for your scope. Maybe an 8-10" SCT or a 80-100mm refractor would be a good start. The smaller refractor will work for visual, but will not do as well on DSO as aperture rules on this.
Posted 03/07/2007 01:27PM #3
Astrophotography is not easy, and Dobs are not suited to the task. For anything but snapshots of the moon, you need a tracking mount.
A good place to learn is a small refractor. Their short focal length makes wide field imaging relatively easy. When you have focusing and exposure down pretty well, you may want to move on to a larger scope like a newt, or the ever popular SCT. SCT's are a little difficult to learn on because of their higher magnification and smaller field of view.
But the most critical elelmlent is a proper mount. THat is where the money has to go.
