Need help with Accessories..... :)
Started by Emanuele, 04/24/2004 04:36PM
Posted 04/24/2004 04:36PM Opening Post
Morning guys....happy AStronomy day to everyone!
smile
I have a question for you and would very much appreciate help:
I'm just starting Astrophotography and yesterday I bought a 300D smile
1 - Is the MaxView DSLR™ Eyepiece Projection Adapters from
scpetronix good? Do I need to pick up any T-rings or something like
that or the MAxview is sufficent?
2 - I don`t have a Wedge. Should I buy one?
3 - What can I use as an AUTOGUIDER? It must be very cheap, because
I'm currently broke and not eating. wink
4 - Should I pick up the Meade Weights Set?
5 - Anything I need to know or should pick up?
Thanks very much and hope to have an answer soon!
Emanuele
www.backyardskies.com
Posted 04/24/2004 07:54PM #1
anyone for me, please
smile
Posted 04/24/2004 08:17PM #2
Emanuele, I'll try to help, even though I'm not doing Astrophotography yet... (hopefully soon smile )
1. Scopetronix has tons of adapters, and I've heard good things about them, but I guess it all depends on what you have, and what you want to do, to choose which one you'll need...
2. A Wedge is REALLY necessary when you plan on taking LONG exposure photos. Alt-Az might be fine if you take multiple very short exposure shots (seconds, not minutes)
3. I've seen people using webcams as autoguiders, but doubt you'll find a CHEAP "REAL" autoguider for less than $500...
4. Depending on your scope setup/mount, and what accessories you'll have on it, you might need to get a weight balance set... (if you are in Alt-Az it is easier than in equatorial mode...)
I wish I could be of more help, but as I said, I'm not doing AP yet...
Clear skies!
Ivan
smile
Posted 04/25/2004 02:32PM #3
I guess you have some kind of fork mounted Meade scope. I wouldn't waste my money on the Maxview DSLR eyepiece projection adapter. I would get a 6.3 focal reducer instead, and just mount the camera straight to that with the proper adapter and forget about eyepiece projection for now. I would definetly get a good wedge. If I was low on funds, I would make my own weight set instead of buying the Meade one. Some people have good luck using a webcam as an autoguider, I use an SBIG ST-237A as my autoguider. You will need a remote for your camera and a copy of Images Plus for your processing.
Ralph
