New Scope
Started by urich, 06/25/2004 01:54AM
Posted 06/25/2004 01:54AM Opening Post
I.m still new to the hobby I got a meade ext90 tbe auto star broke the first night my luck I would like to up grade to the meade LX200 12" GPS next year. My question is two fold 1 How much more will I see with the LX200 I see very little with the 90? 2 Will it be worth the 3G I spend? thanks J
Posted 06/25/2004 06:19PM #1
Hi J,
You would definitely see much more, but at the expense of having to haul around a heavy scope. As a sidenote, the best scope is one you use most often, which means a good consideration would also be ease of use and portability. Hope this helps. Clear Skies!
Derrick
Posted 06/25/2004 08:39PM #2
You are a star party candidate. No scope may match your expectations. I suggest a local club, or a starparty event, so you can look through many scopes. You may get tired of hauling a 12" LX200 around really fast.
Good Luck,
Richard
Posted 06/26/2004 12:49AM | Edited 06/26/2004 12:50AM #3
A lot of good posts and advice. I think that you would be surprised at how much you can see through your ETX if you can get it to a dark site. I logged around 60 Messier objects on my first night out at our local club's site (with my ETX-90). I upgraded to a 10" GPS scope, but limited myself to something I could easilly move, which is something you should definitely consider. In any case, go to a star party somewhere and take a look through a variety of scopes. You may find that you don't see enough difference between an 8" and a 10" or a 10" and a 12" to justify the extra expense and weight.
Best of luck
Peter.
Posted 06/26/2004 04:13AM #4
8) I was thinking of a 12" also but I had the sense to look at the weight before I bought. If you can mount that scope permanently in your backyard and keep it out of the weather and secure by all means buy it. If not, you had better settle for a 10".
I'll tell you lugging that 65# up on the tripod and then screwing in the baseplate without dropping it is about all I can do. I don't think I could make it with the 12".
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety."
