Ghost of Cassiopeia
ORION ED80 & ED100, Focuser options?
Started by IGastaldo, 04/08/2005 03:55AM
Posted 04/08/2005 03:55AM Opening Post
What focuser alternatives are out there to replace the stock focusers that these scopes come with? is anybody here using any of them? what's your opinion about it?
Thank you for your attention, and clear skies!
Posted 04/08/2005 06:10AM #1
Hi Ivan,
I have an ED80, and must have gotten one of the "bad" stock focusers. Squeaky, excessive play(slop?), and couldn't get everything lined up well enough to produce concentric rings when using a refractor collimating eyepiece(sight-tube?(from ScopeStuff)).
But the optics were quite good, and I didn't want to send it back only to get a unit with a smooth, fault-free focuser, but so-so optics.
So I VERY skeptically ordered a Moonlite CR2(?) dual-speed focuser, using the reasoning that even with almost 400-bux invested in the focuser, my total cost is still under $1K, and I would end up with a pretty sweet scope.
The focuser itself is like a work of art, I'm sure the feather-touch focusers maybe a bit "finer"(I've never had the pleasure of using one of them myself) but after all appropriate adapters and such they are also significantly(to me anyway) more expensive.
One surprise was, with the stock crayford, no matter how many times I fooled around with the mounting screws and did the "wiggle it around-tighten-loosen-wiggle it around-tighten..." I couldn't get the collimation/alignment good enough to my own satisfaction. But with the Moonlite, I just slid it in the tube and seated it firmly against the tube end, and voila, the rings are REAL close to being perfectly concentric. Much better than I could ever get rocking the stock focuser around. They're still ever so slightly out, but not worth fussing with to get it better. The Moonlite is adjustable/collimatable but must be removed from the tube for each adjustment, and I just haven't been willing to bother with it thus far.
And to make sure I just didn't get lucky, I did the unthinkable and removed the focuser completely and reinstalled it, with identical results. One day I may go through the trouble of getting everything as "absolutely perfect" as possible, but being that I have no way of knowing whether or not my $30 collimating ep is itself perfect, it may be a waste of time to bother getting it any better.
One point to consider, is that I believe the ED80 and ED100 have different length drawtubes, while the Moonlite units, AFAIK, come with only one drawtube length, with no option for other lengths. Although I'm sure they could/would be willing to provide a custom length tube if one wanted one.
ED80/100 focuser upgrade is HIGHLY recommended IMHO.
Take care,
Posted 04/08/2005 03:11PM #2
Thanks for your replies gentlemen... really appreciated!
Clear skies!
