WR 134
Quality Secondary Adjustment
Started by Jud, 12/01/2005 01:49PM
Posted 12/01/2005 01:49PM Opening Post
Is there a better way/equipment to adjust the secondary than loosening one or more of the three screws and twisting it by hand. There seems to be too much room for error in setting the secondary angle. I have a 12" HOC dob. I envision a setscrew setup forward of the spider with a rotating sleeve through the spider assembly. Guess I haven't bothered to look at enough telescopes to know any better. Any help?
I Yam What I Yam!
Posted 12/01/2005 02:37PM #1
You should not loosen all three screws and adjust by hand.
You should slightly loosen one screw as you tighten (slightly) the other two.
All screws should remain fairly tight through the whole process.
This will give very precise adjustments.
