Hi I have a Meade AR6 and have a question about Airy Disks. The collimation on my scope is perfect from what I can tell on both sides of focus. But when I have a bright star in focus at high power(more then 200x) I see about 4 Airy Disks around it. The “problem” that I see is that they are significantly brighter on one side then the other. Star itself is a perfect little orb very similar to an APO but not quite as perfect. I know this is not the diagonal as I have tried to remove it and get the same thing. Also at very high powers the airy disk’s become quite large and noticeable, should they be so prominent? Any thoughts about the uneven brightness? Thanks.
Question about Airy Disk on AR6
Started by power_overwhelming, 09/03/2003 02:16PM
Posted 09/03/2003 02:16PM
Opening Post
Posted 09/03/2003 02:31PM
#1
No obvious ideas from me...have you eliminated the eyepiece as the cause? Thomas Back has provided an excellent star test procedure at:
http://voltaire.csun.edu/tmb/tmb4.html
As he suggests, use filters to isolate chromatic and sphero-chromatic aberrations. I have seen such aberrations in my Meade AR5 (127mm f/9.3) when CCD imaging Mars, and would expect a more pronounced error in the 150mm f/8 optic.
My old Celestron (Synta) CR150 did not have a "perfect" intra and extra focal pattern, but performance was still excellent for an achro doublet.
Funding Member
