Hi All,
I got a used Orion Intelliscope 8' from one of the users here. Seems like normal wear and tear and the sale was really great. I decided to start on Saturn and noticed that it was very "bright". It looked washed out like the moon does. So I decided maybe I shopuld recollimate. I did a lot of reading and it didnt seem to make it any better. So, on impulse (is there any other way?) I bought a laser collimator for 40 bucks and tried it that way. Brought it outside and tried it. A little sharper, but still bright. A friend tells me I should be able to see the cassini division with no problem. I brought it back inside and just for a lark I checked the collimation again and it was off. It was then I discovered my fatal flaw which was my not turning down the screws to hold the lens in place. Tuned the screw and it went back into alignment. Hmmmm. Just for the fun of it, I moved the focuser. To my surprise, The red dot moved almost 5 mm out of the circle. I took apart the rack and pinion gear set and tightened up the springs and reinstalled it. It helped a little but I still get a lot of play out of the focuser.
My questions:
1. Is it normal to have this much play in a focuser? ( Stock Orion)
2. If I tighten the hold bolt( gently) and then turn the colllimator, the dot moves. Is this normal?
My questions:
