RE: Orion 9x50 Correct Image Finder Mount
Started by Pongfu, 05/17/2008 10:57PM
Posted 05/17/2008 10:57PM Opening Post
I was given an Orion 9x50 corrected image finder without any mounting hardware. I have an 8" Meade telescope I was thinking about mounting it on. However, I don't know what kind of mount to get for it. Or, if possible, I could manufature something for it. Has anyone come across a similar situation and have any ideas what I could do? Does anyone have an Meade finder mounts that might work for this thing?
Thanks
Posted 05/17/2008 11:33PM | Edited 05/17/2008 11:38PM #1
Thanks>>>
http://www.buytelescopes.com/product_list.asp?t=69
Anacortes has all kinds of option.
Posted 05/18/2008 10:56AM #2
Hi:
I have one of these finders and I like it.
These are quite short so they maybe too short to fit in some 50mm finder mounts. I just compared the RACI mount to the standard Orion/Celestron/GSO straight through finder mount and they appear to be identical.
So my suggestion would be to place an want ad for a stock/orginal finder mount of the type that would fit your scope, either the SCT (for the SCT) or Dovetail for other scopes.
Posted 05/18/2008 03:22PM #3
Thanks
Any 50mm finder work of the single ring variety will work. One of those Orion sells, for example.
The only limitation is that if you use a two ring finder mount, make sure the two rings are not too widely spaced.
8)
Uncle Rod
Time on your hands?
Posted 05/20/2008 01:16AM #4
Charles, I'm not clear on what you are missing. However, if it's the mounting base, they are available seperately from Orion. Check here:
http://www.telescope.com/control/keywordsearch/~clearSearch=N/~VIEW_INDEX=1/~VIEW_SIZE=11
