Any thoughts on these? Any other scopes recommended? Thanks in advance!!!
1. Space Probe 130. F6.9, this scope has a spherical mirror, too fast to be diffraction limited with a spherical, needs a parabolic.
2. Space Probe 130ST. I have one of these OTAs in my collection. Mine has a 2 inch focuser. I like this scope and consider it a sleeper, at 650mm focal length it does some nice wide field views, barlowed up, I have gotten some very sharp views of Saturn, the Cassini all the way and sharp, detail on the body 250X). On double stars I have taken it to over 500x, double barlowed (on good nights and I was seeing nice round airy disc's. I use mine on a EQ-3 mount, the eq-2 mount is marginal in my view but optically this scope reminds me of a half-pin 10inch Asian DOB, nice...
XT-6. Probably the scope of choice, good on the planets, good on DSOs, collimation is going to be easy. THe mount will be solid and the scope easy to use. If you can see your way to a 8 inch DOB, you will have a killer scope. I have an XT-8 and it is a great scope, easy to handle, gives nice sharp images and really does well on DSOs.
I don't see the 90mm F10 refractor as comparable. on a good night, the XT-6 should best it comfortably on the planets, on DSOs the fact that the XT-6 has almost 3 times the mirror area will light up the sky in comparison. The comment that the sky was blacker in the smaller scope, this is always the case, especially when there is any light pollution at all. The light pollution is magnified and collected just like the starlight. But the larger aperture will see more regardless. Normally my backyard sky is pretty grey in my 12.5 inch until I reach 200X or more, but I am seeing more detail and fainter objects none the less.
The advantage of the refractor is it is pretty fool proof, though refractors can need collimation just like Newtonians. And achromatic refractors do suffer from false color, even relatively slow ones like the 90mm F10 will have some, a Newtonian is perfect in this regard.
But as someone else pointed out, the best thing to do is get out there as see for yourself. Don't be satified with a look at the Orion Nebula, its a grand view in any scope I have ever used. Make the scope work, check out M46 and see if you can spot the hidden planetary, check out M93 and see how bright it looks and how many stars are there to see...
Of the scopes you suggested, I think the XT-6 would probably be your best bet, the SpaceProbe 130ST, is certainly an option and can provide widefield views that are not possible in most other scopes. Fitted with a 2 inch focuser, it will do something like 3.5 degrees at 20X, pretty amazing, the summer Milky Way explodes in valleys and rivers of nebulosity at 20X....
Best wishes to all,
Jon Isaacs
