Rigel Quikfinder v Telrad
Started by Barberskum, 02/16/2022 01:11AM
Posted 02/16/2022 01:11AM Opening Post
Hey all.
Hope it's ok to share here! 🙂
I've used various types of view finders over the years on different model scopes. Each with their own pros and cons. I have found though that switching to a Telrad has made the process of alignment a lot easier. On larger scopes I have the extra bulk and weight is not a big issue but on smaller scopes where every ounce may count then a smaller / lighter alternative is good to have!
Having bought one I decided to make a Rigel Quikfinder comparison / review so I hope this is someway helpful if you're thinking about changing your viewfinder.
Clear skies!
Frank
Posted 02/20/2022 08:27AM #1
Here is a repeat of my comment on your video (very nice, BTW):
I prefer the Rigel (cheaper, lighter, etc.) and I use them on my 5", 8", and 11" SCTs.  My biggest gripe with the Telrad is that the top back corners of the viewing glass are fairly sharp.  Twice, while moving in to look through a friend's scope, I have cut my forehead on the Telrad because my friends had mounted the Telrad as far back as they could on the telescope tube instead of moving it forward a safe distance.  The corners of the Rigel are nicely rounded and do not present a hazard.
Posted 02/21/2022 07:25PM #2
Thanks Fred!
It's a good thing you pointed this out (excuse the pun) as it's defiantly something to be aware of.
