Gary Taylor
M27 - Dumbell Nebula
Rotating Rings
Started by RUSTY845, 05/08/2006 05:11AM
Posted 05/08/2006 05:11AM Opening Post
Hi All: I just got an Atlas EQ-G, with Parallax asking $480.00 for a set of 10" rings rotating rings, I was wondering if anyone has a set of plans on building rotating ringe, and if you would like to share they. I have a buddy that works in a power plant machine shop and is willing to make them up for me.
Thanks you any help
Bob
R.A.C. Advisory Committee
NEAIC Co-Chairman
NEAF Advisory Committee
Warwick, New York
41.15984 -74.2541
[B]Takahashi MT 160
10" F4.5 Newt 8O
R200SS grin
Some kind of 127mm APO
Orion Atlas EQ-G
Losmandy G11 with Gemini
iOptron Mimi Tower
iOptrom Cube Pro
Meade DSI PRO II 8O
SBIG ST-10ME
Image Source 21AU04.AS
Posted 05/08/2006 05:35AM #1
Hi Robert:
I don't have any plans for rotating rings for you.
I will repeat the suggestion that was made to me when I faced a similar situation, This was to purchase an extra mounting ring (only available as pairs of course) and put it above the top ring on mount, just clamped to the OTA. This keeps the scope from sliding down when loosening the mounting rings to rotate scope.
I have found that I can leave the rings alone, loose enough to rotate, tight enough to avoid vibration problems.
Not quite like real rotating rings but a whole lot cheaper.
