Bat and Squid
Schmidt-Cass Corrector Lens Rotation
Started by astrogretz, 08/09/2002 05:40PM
Posted 08/09/2002 05:40PM Opening Post
Hi, has anyone heard of rotating the corrector lens to improve optical performance?
Thanks, Andy
Posted 08/10/2002 10:53PM #1
Hi Andy,
I have heard of this. Any compound optical system can be made better or worse by changing the radial alignment of its radially symmetric components. For example I see a tad of astigmatism at 500x through my 12" SCT so I am going to experiment with changing the centering of the corrector plate in its cell (with the cork pads around its circumference) as well as try a turn of the plate by about twenty degrees at a time. But remember that the secondary will rotate with the plate unless you make an effort to realign the secondary relative to the primary (keep its top facing up -remember to mark it on its top edge so you know how it originally was aligned).
So go for it. Just be careful to make sure you know how to set the original alignment if you find that rotating the plate and / or secondary does not help your images.
Here is another thing to consider: The SCT design only has perfect spherical correction for one focus position. So if you pull your diaganol out a ways (or view straight through) so as to change the distance from the focal plane to the secondary mirror, you will change the spherical correction of the system. Here is an example: when I view straight through (no diaganol) in my 12" SCT I see nearly a perfect breakout pattern of the secondary shadow, nearly the same size on either side of focus but slightly different. If I pull my drawtube out a little ways and view again after refocusing, I see perfect star test patterns. If I put my diaganol in, I see the star test becomes asymmetrical opposite of how it was when just straight through.
What really matters with a compound system like an SCT or Mak is not perfect spherical correction, it is smoothness of the optics. Rough optics in any scope will mess up your images BADLY even if the star test shows no spherical aberration. But a smoothly figured 12" SCT is spectacular on planets, easily beating a 6" APO refractor despite having a 33% central obstruction.
Jeff Quinn
