Shaft coupler for Robofocus
Started by Needtoys, 06/05/2007 11:35AM
Posted 06/05/2007 11:35AM Opening Post
I know this is a long shot but I'm going to try.
I'm searching for a slip clutched shaft coupler. I want to mount my Robofocus motor to my stock Tak focuser and still have the manual focus knob option.
I found the perfect coupler at Mcmaster-Carr. It's a Precision, adjustable Torque-Limiting, Flexible Coupling with zero backlash, but it's $340. 8O
Has anyone tried this before and maybe have a cheaper alternative?
Bob Hayes
http://community.webshots.com/user/phatbob02
http://outdoors.webshots.com/slideshow/550511533ICdPnP
Why does someone believe you when you say there are four billion stars, but check when you say the paint is wet?
Posted 06/05/2007 02:37PM #1
Hi Bob,
Look up McMaster-Carr part #: 9132k11
It's under miniature slip clutches, page 993.
When you want to disengage the RoboFocus, you just turn the clutch.
You lose the 'Home' position for the focus travel when you do this, so you'll probably want to recalibrate it every so often so you don't get into trouble.
Here's a blurry image of this clutch:
http://members.cox.net/dakoan/Jenkins%20bracket,2.jpg
I hope this helps,
dan kowall
