Ghost of Cassiopeia
smallest scope & least mag. for Mars detail?
Started by light trap, 09/01/2003 01:45PM
Posted 09/01/2003 01:45PM Opening Post
What's the smallest scope, and the least amount of magnification that folks can consistantly see defined dark areas of Mars with?
Previously, based on experiments with a variety of small scopes, and with comments I've seen on several forums, I had thought that there wasn't much point in going below about 100x100mm, with 120x120mm being far preferable. With good filtration, I find that I can regularly see the ice cap at just about anything above 48x70mm, but don't tend to see dark shading until moving up to *at least* a 100mm scope. So far, I've not been able to see much with the 70mm Ranger at any magnification or filter. However, I've seen some sketches on the web that show a good amount of dark detail with a 118x60mm when Mars wasn't even as close or as bright!!!!
Obviously, this has a lot to do with the skill of the observer and the seeing conditions. But, I'm curious if there's any group concensus as to a lower limit for being able to really discern consistant detail, (not just imaginative speculation).
Mike Swaim
Posted 09/01/2003 02:08PM #1
I recently pulled my old 50mm Tasco out of its box and piggybacked it on my C8. Using a very cheesy setup with masking tape, I put my 1.25" Ortho on the .965" scope and pointed it towards Mars.
Surprisingly (at least to me) I easily saw the tiny SPC as well as light and dark areas on the disk. I did a quick and very cursory sketch and it roughly correlated to what later I saw in the C8. I need to try this again; maybe bumping up the magnification from 86x (though it won't take a barlow so I can only go up a little).
I got some real satisfaction from what I could see. This is my starter scope from 1968, and I remember the Mars opposition in 1971 and how all I could see at 120x was a featureless orange ball--- there was a global sand storm then. 30+ years in the making but the Tasco finally hit its mark on Mars!
I think it's an okay scope. Tiny, yes, but not a toy like you easily get bit by nowadays.
Cheers.
Tim
Posted 09/01/2003 02:23PM #2
I can see the SPC and limited dark shading with my 80's vintage Celestron/ Vixen 60mm F5. If I remember correctly, I used 83x and 120x and the views were surprisingly good at both magnifications. I have also used a Vixen FL80S fluorite scope (80mm, F8) quite a bit on Mars. I have been able to discern the "Eye of Mars" (Solis Lacus) and Mare Sirenum as well as Syrtis Major and a couple other features using a variety of magnifications. I use 178x and 145x most often with that scope.
Posted 09/01/2003 02:30PM #3
Hello there Mike,
A most interesting question indeed. I don't know what is the minimum, but I repeated Huygens' discovery of Syrtis Major back in Nov. 28, 1659. He used a "home made" ;-) telescope of 51mm aperture (before the time of the achromat) and his "home made" Huygens eyepiece yielding 50x. Mars was 17" in apparent size at the time. I followed his historic discovery (granted with far superior optics ;-).
http://members.cox.net/ronby/Solar-System/Mars-070203.htm
If anyone is interesting in trying out the "Huygens' Challenge" (as my Light Cup called it ;-), Mars will be 17" in size again in mid Oct.
Ron B[ee]
Posted 09/01/2003 02:37PM #4
Hi Mike,
If you've got really good optics (meaning very well figured with a smooth microfinish), the sweet spot for observing planets typically falls between 10" and 14" at around 200x given acceptable seeing conditions. I've seen some great views of Mars in good 4" scopes (APOs), but the amont of detail just doesn't compare with a view from a good scope with more aperture.
So to answer your question on what the lower limit is...it depends on how much detail you *want* to see.
Bret
Posted 09/01/2003 02:56PM #5
Perhaps "consistently see" is the crux of your question. And when... this year, last year or next year?
For the past month, with a Tak FS78 using an Pentax O-7mm at only 90x, I have usually seen defined dark areas unless the seeing was totally boiling.
With a Tak LE 5mm (126x) in the 3" scope, I have consistently seen defined dark areas.
Posted 09/01/2003 04:16PM #6
Here's what I experienced, back in July:
http://www.astromart.com/messages.asp?message_id=88889&page=
http://www.astromart.com/messages.asp?message_id=88888&page=
http://www.astromart.com/messages.asp?message_id=88883&page=
No doubt, things would be a bit easier if I tried the experiment again, over the next few days.
...Hmmm... Maybe I will. :-)
Cheers.
-Dan
