Ruben Tommasi
Andromeda Galaxy (M31)
Super Polaris Mount question
Started by tomdisco, 02/08/2004 03:32PM
Posted 02/08/2004 03:32PM Opening Post
The photo below shows the manual R.A. control of my Super Polaris mount of mid 1980's vintage.
Newer non-electric models show the metal box that would house an optional R.A. drive motor which I understand is identical to the CG-5 motor assembly. Also, the metal motor housing box normally slides up a plate which is part of the axis housing. The motor bracket is normally anchored into that plate with mounting screws.
My Super Polaris model has no motor housing box and the axis housing has no mounting plate for a motor. If I wanted to acquire a R.A. drive for this mount what do I ask for and how would it attach?
tomdisco's attachment for post 13011
Posted 02/08/2004 03:57PM #1
Jim,
To install a Vixen RA motor, you would remove to silver cover(flat area below worm housing). The Vixen motor assembly has a dovetail cast into its housing which mates to this receiver. I'll send you a pic if you would like one.
Regards,
Tom Tolla
Tom T.
Guilford, CT smile
Posted 02/08/2004 04:15PM #2
James,
See the 4 set screws (2 on each side) that hold the lower (narrow) cover plate on. Loosen those until you can remove the cover plate. The original Vixen motor dovetail sits in that grove and is adjusted and held in place with the 4 set screws. There is also a long bolt that passes from the back of the mount (opposite the motor) that holds the original vixen motor into place. The 4 set screws can be used to fine tune the mesh of the gears to minimize slop.
The CG-5 motors can be mounted to the SP but they are not identical and may require a bit more tinkering.
Hope that helps some,
John
