Opinions on the combination. Would like to mount one on a G11. Does the chromacor really approach APO views?
Synta 150mm and chromacor
Started by mpinson, 02/18/2003 03:28PM
Posted 02/18/2003 03:28PM
Opening Post
Posted 02/18/2003 05:51PM
#2
Marty,
Quick answer is "yes, it does approach APO views."
But you do have to put in some work to get there --
collimation of the Synta needs to be pretty good, and
you may need to experiment with spacing / rotating
the Chromacor in your scope. But if you like tinkering
with this stuff, you'll have alot of fun and get some
great views when you're done.
Here's a couple of my past posts on the subject:
http://www.astromart.com/messages.asp?message_id=2777
http://www.astromart.com/messages.asp?message_id=4220
http://www.astromart.com/messages.asp?message_id=24960
http://www.astromart.com/messages.asp?message_id=30411
http://www.astromart.com/messages.asp?message_id=39481
G-11 should be fine; probably even a little more
mount than you need. I used it on a CG-5.
Best wishes, - John B.
Posted 02/19/2003 03:32AM
#4
I sampled a Chromacorr equipped Synta 120mm refractor and they were a good combination for color correction, like a good semi-apo (Meade ED or Vixen 102ED class color correction). Fine detail left much to be desired and was completely inferior to my 152ED. A G11 is a good mount for a light 6" refractor. Ed Ting even thinks a GM-8 is suitable.
Funding Member
