T-rings, correct one ? help?
Started by Brianpope, 02/28/2004 12:09AM
Posted 02/28/2004 12:09AM Opening Post
Hi all,maybe wrong forum but i will post in both. I Have a Pentax k1000. I have a t-ring I have had for some time that has pentax k/m on it and this one has a raised side(its the one on the right in pic). I just aquired another T ring with T P/k - af on it. Now this one has no raised side at all and is basically flat. Which one am i supposed to use they are very different?
Thanks for hte help
Brianpope's attachment for post 13579
Posted 02/28/2004 03:00AM #1
Brian,
The left one says PK-AF, where AF presumably means autofocus (which your K1000 does not). It may however be the same as the right one though.
My guess is that the one that is not 'flat' - ie the one on the right is coming apart. If you have a jeweler's screwdriver, try loosening the set-screw(s) and screw it back together, then tighten the screws.
Hope that's it...
Malcolm.
mshedden's attachment for post 76880
