Tear-out designer foam
Started by Bob Arr, 05/28/2004 05:16PM
Posted 05/28/2004 05:16PM Opening Post
Does anybody know a source for the foam padding that is covered with
a grid of cuts halfway through the foam? The cuts are 1/2" apart, and
intended to allow the use to tear out small columns of foam, half the
depth of the pad, leaving a cavity shaped to hold an object snugly.
It's ideal for eyepieces and related astronomy equipment.
Lowe's sells an attache case ($25) that comes with this foam
installed, but I want to use it in a custom job. Maybe more than one
job, if it works well. I could use about 4 square feet, 3" thick.
Thanks for any help.
Bob Arr
Posted 05/28/2004 06:21PM #1
Bob,
I believe Pelican cases come with the sort of foam you want. They sell replacement inserts for their cases. Try Pelican, or CasesforLess.com.
Good luck,
David Vaughn
Posted 05/28/2004 06:22PM #2
Bob
Do a Google Search for "pluck foam" and you will find more places to find this stuff than you will ever need. Pelican makes replacement sets for all their cases and www.casesbypelican.com/foam.htm has the polyethelene foam also which is closed cell and much firmer than polyurethene.
Hope this helps
Buck
Posted 06/02/2004 02:28PM #3
Thanks for the replies.
Turns out nobody sells this stuff reasonably. Orion no longercarries it, Pelican offers a small quantity for $60 (you can
buy case and all for $25 at Lowes), and the enormous list generated
by Google consists 90% of deadend duplications.
I have been lucky. A friend who works for a company that had
a lot of leftover pluck foam saved the scraps and gave them to me.It's enough to do my job. But I pity the next guy who needs it.
Bob Arr
