Hello folks:
I own a 14" LX200GPS which I have been happily using (with no problems) for just over a year now. All has been working well... until Wednesday's eclipse. I had my telescope tracking the moon. I went inside for a short while and when I returned, I found the telescope had basically stopped tracking. The Autostar was displaying "Moon..." etc, but did not respond to any keystrokes. I re-booted the telescope, but it has since refused to spark to life. I hear the chirp when I turn it the telescope on, but the Autostar light quickly fades to dim (not off) and no message appears. I brought the telescope back inside and tried again in the morning. Essentially, the telescope no longer wants to fire up. I'm not sure what the problem is.
I'm aware that the Autostar II handbox for the LX200GPS, has no brains (unlike the Autostar 497 - which does). My first guess would be loose wiring, but I took the base plate off (I installed stainless steel gears last spring, so I'm reasonably familiar with this) to make sure there are no loose wires, etc. there aren't. My second step will be to find someone here in Edmonton (Canada) who also owns an LX200GPS to see if the problem isn't the Autostar handbox (i.e. if it works on another LX200GPS, I could rule out the Autostar as being at fault). Yes, I have called Meade, and yes, they suggest sending the scope to California for them to have a look at it... Did I mention it's about one month past the one year warranty? (Go figure)!
Obviously, the last thing I want to do is to ship the scope back (at my expense - along with $US350 for the "extended warranty"). At any rate, I'm throwing this out to see if anybody has had the same problem, and what their soulution might have been. (BTW I have always used the recommended #547 AC adapter).
Thanks for reading and I look forward to any replies.
Regards,
Sparky.
Regards,
Sparky.
