Tube Currents
Started by Kevin, 06/27/2009 03:35PM
Posted 06/27/2009 03:35PM Opening Post
Gents, I am trying to collimate an Astro-Tech 6" RC for a friend and clubmember. This type has a factory fixed primary and they intend you to collimate with secondary alone which seems a bit different that your standard RC according to what I read.
Right away, I noticed pretty severe tube currents which is what I believe he is seeing rather than an out of collimation scope. These lasted for a looong time. Is this typical of this design? The scope was brought out from a 73 degree house, to a 65 degree nite and was set up at 9:45. By 11:20, it was just beginning to settle down enough to see round fresnel rings. I've had SCTs that cool faster than that. Do the baffles affect this?
Kevin
Posted 06/28/2009 01:19AM | Edited 06/28/2009 01:22AM #1
Kevin
Well Roland just posted that on refractors you want the aluminum tube shrinkage to match the change in the curvature of the lens.
However, on Yahoo C14--totally different design of course--the opinion is that the carbon fiber does indeed help one stay with one focus point. People make the switch and they report good results.
Getting to the thermodynamics of the SCT, I have studied it in my rudimentary way. The aluminum OTA is extremely efficient at radiating heat, and the heavy rear casting, while also a "heat sink" that might on the one hand prolong cooldown, is also pretty a pretty good radiator and you get conduction through the baffle and the thick part of the mirror.
Certainly the major tube current in my C14, I was surprised to find out there with my infrared zapper, is not from the mirror to the top but from the ground side to the sky side. The temperature delta is huge and swamps almost any other thermodynamic in the tube, nearly as I can see.
Running the *internal* dew heater at 22 watts sounds like a thermal nightmare. In fact it barely provides enough heat to keep the corrector clear. (A larger external dew heater would fail to heat the corrector enough). But it seems to be that even though the internal dew heater is not in direct contact with the aluminum, the sky/ground dynamic is the main source of currents. If you zap the corrector (the IR gizmo reads the glass temperature) and the aluminum nearest to the dew heater, there is very little delta from ambient. Total variation over the corrector is no more than a degree and it too is very close to ambient.
This behavior is completely at odds with what I registered in garage experiments when, with the same rig, I easily jacked the corrector plate up to 5 or 6 degrees above garage ambient. The difference is in the radiative cooling, for me this was a lesson in physics. The heated garage walls are warm so there is very little radiative loss on inside experiments.
Your baffles, if made of aluminum, are still inside carbon fiber, so even if they are aluminum, their largest exposed area is not to the sky but to the carbon fiber which doesn't want to radiate to the exterior or for that matter absorb heat losses from the aluminum baffles. So yeah it seems to me this could slow things down relative to a 100% aluminum OTA. Basically the only way you have of losing heat is through convection from the mirror out the top end, and it seems like that isn't working too well.
For reasons I consider mysterious, my C14 cools down more quickly than my friend's 15" Obsession, whose mirror is surrounded by wood and sometimes is in a shroud and sometimes is not. But maybe the conical design of the SCT primary helps.
Given all this it is surprising, but not a total surprise, that the carbon fiber open tube may be on the slow side to cool down, but jeeze, six inches just aint much, and if it has a hole in it and is conical, the largest optical real estate on the edges should cool fairly readily.
But if you're looking for a solution I'd say the standard dob procedure of having a fan blow across the thermal boundary would probably be your best bet. I think that 90% of the optical cruddiness is in the first inch over the mirror. Another solution would be, when you take the thing outside, to put a fan up the behind of the OTA to improve the efficiency of the convection cooling.
regards
Greg N
