Sculptor Galaxy (NGC 253)
Tube modifications
Started by n.i.x, 11/20/2003 07:21PM
Posted 11/20/2003 07:21PM Opening Post
Ok, this weekend I would like to add a fan to my tube at the back of the primary. This would require ventilation holes at the front but there is only about 7 mm of spacing around the corrector (Schmidt-Newton scope) so the holes to be drilled could be no more than 4-5 mm. Would 50-60 holes be enough for ventilation?
Thanks for any input..
Nico
Posted 11/20/2003 07:27PM #1
Are you sure you need to drill a lot of holes?
You might just need to have a fan and an exit hole for ventilation. They might be able to be made in the end of the tube if there is room there. A smaller computer fan could do the job. I am not sure whether I would add that many holes. I would also have to consider using filters for a closed tube like yours. I would filter the air being drawn into the tube and even have a filter for the exit hole. This would help to keep the dirt from gettin into the closed tube on onto your corrector plate.
Floyd
Posted 11/20/2003 08:58PM #2
IF you have to ventilate, you would probably be better off with two, larger holes drilled into the SIDE of the tube about 2" back of the corrector. 50-60 holes around the thin metal supporting the corrector could cause a disaster. Either way, the whole thing will have to have all optics removed and other parts (focuser, etc.) masked off or the shavings from drilling could cause big-time damage. A filtered fan at the back and two filtered holes near the top sounds a lot more feasable.
S. Sherrod
Posted 11/20/2003 10:51PM #3
Here's how it looks; the highlighted part on the rear-end shows the cardboard mirror-protection to be removed so the circular opening can accommodate the fan..
Nico
n.i.x's attachment for post 73354
