ULS quartz secondary upgrade
Started by DavidU, 05/11/2003 12:18AM
Posted 05/11/2003 12:18AM Opening Post
I was thinking of an upgrade with a quality quartz secondary,mainly because of the excellent surface polish they have. Has anyone had good results with this type of upgrade?
Posted 05/11/2003 03:27AM #1
I upgraded to one of Protostar's premium quartz diagonals but only noticed the wave front improvement on nights of excellent seeing. There does seem to be less scatter as well. Sure can't hurt!
Posted 05/11/2003 07:01AM #2
I've used several of these and believe I can see the difference on nights of excellent seeing. And it's a small difference to pay for guaranteed excellence from one of your two mirrors. (i.e. so just do it ).
Good luck!
Posted 05/11/2003 02:31PM #3
I installed one of these and it was definitly
a "downgrade." The mirror had a small
un-aluminimzed region at the edge (most of them
do). At first I didn't think it would matter,
but it makes a huge diffration spike across the
field on anything bright. Very expensive mistake.
Posted 05/12/2003 12:40AM #4
David,
You don't say how good the surface accuracy of your current mirror is-- going from a run of the mill 1/10 wave secondary-- possibly with a turned down edge-- to the typical "quartz quality" uniformity of flatness will make a huge difference. IMO this is probably even more significant than the backscatter reduction from the smoother polish. I recently upgraded an indifferent quality (and poorly mounted) Meade 4" secondary to a high quality (1/15th wave, 1/100 RMS, Zygo certified) Pyrex 3.1" one, and the difference was like night and day! Together with a 0.25" masking of my primary to cover the mirror clips and a TDE, I was able to *double* my useful magnification ceiling from 360X to 700X on a 16" scope. I'm beeh toying around with the idea of having a custom-made 1/20 wave 3.1" quartz diagonal made to see if it yields any further performance increase over the Pyrex one. I probably wouldn't see the difference in performance more than a couple of times per year, at best.
Jim
