james carter
North American Nebula NGC7000
Using a cheshire eyepiece on a refractor
Started by Bill in Ballard, 11/06/2004 03:38PM
Posted 11/06/2004 03:38PM Opening Post
I recently picked up a cheshire eyepiece to collimate my refractors.
I wonder if I'm doing something wrong because the reflected light circles move if the light source is held at different angles or distances from the eyepiece. If I hold it one way I get one overlapping pattern. If I hold it another I get two distinctly separate reflected discs.
I'm using a small maglite and wonder if that is too powerful, and might be part of the problem.
Any info on how to best use the cheshire eyepiece would be greatly appreciated. thank you, Bill
Posted 11/07/2004 02:07AM #1
Tape a piece of paper over the opening of the Cheshire, which will diffuse the light.
Joe Bergeron
Moderator, Astro-Physics Forum
Posted 11/07/2004 07:00AM | Edited 11/07/2004 07:36AM #2
Hi Bill,
I have the same problem. I think the maglight has too narrow a beam giving a projected beam angle going into the scope depending on the source angle, giving the effect you see. If the source light is much more diffuse, then the input angle of the light will not make any difference. I think Joe has the right idea. Maybe putting a piece of diffuse clear tape over the entrance hole might help, or use a more diffuse source of light.
My problem is, I would get everything aligned at one focuser position, then if I racked in the focuser, it would be off again :S I think I may have an offset focuser. I have also been doing some tests with a laser to see if the reflected light returns back into the laser. This also looks promising.
David Simons
David Simons's attachment for post 84688
David Simons
Posted 11/07/2004 03:40PM #3
Thanks to everyone for the input. It has already been very helpful. Best to all, Bill
