Wizard Nebula
Using Meade Superwedge on a fixed pier?
Started by TomH, 07/29/2004 08:23PM
Posted 07/29/2004 08:23PM Opening Post
Is there any device (adapter?) which will allow me to use a Meade Superwedge on a home built fixed pier? I'm trying to install a LX200 -10" into a Technical Inovations Robo-Dome.
Thanks in advance,
Tom Hise
Posted 07/29/2004 09:42PM #1
Tom
I have a fixed pier made from 6" schedule 40 pipe. The top is capped with 1/2" steel plate and a 4" round handhole cut in the in side about 6" down. The top has a 1/2" hole in the center for a 1/2" bolt that comes up through the center of the wedge and is tightened with a nut. I can access the bolt through the handhole when tightening. the top also has three 5/16 tapped holes for the lock down screws for the wedge.
Hope this helps.
Steven Jindra
Posted 07/29/2004 10:09PM #2
Tom,
I have no idea what kind of pier you're trying to make, but Dans Pier Plates work very well. I have on in my observatory. It's attached to a 12" concrete pier, worked great.
http://www.pierplates.com/
that's the page for his site. I have some pictures of mine during construction if you want to look. Good luck.
Matthew
http://www.deerrunobservatory.com/
Matthew
http://www.darkgeorgiaskies.com/
