what does triplet mean?
Started by fussellino, 05/01/2003 03:42PM
Posted 05/01/2003 03:42PM Opening Post
what does triplet achromat mean? and is that a good thing vrs doublet or whatever is standard on a refractor?
Posted 05/01/2003 03:47PM #1
There is a third lens element (as opposed to the two in a doublet lens) to further correct for chromatic and spherical aberrations which could otherwise be fairly severe in an f/6 refractor such as the scope just discussed.
Posted 05/01/2003 03:53PM #2
An achromat is typically a telescope that focuses two light wavelengths to the same point whereas an apochromat is a telescope that focuses three to the same point, the objective being to remove chromatic abberation (ie. false color). A doublet is a lens with two elements and a triplet is one with three.
Most standard refractors are achromatic doublets whereas most high end ones are apochromatic triplets.
Posted 05/01/2003 06:13PM #3
this triplet achromat use a doupletwith close airspace and a rear lens in same same with a bit wider spacing. Correspondance to the manufactors infos this help them to get a bit flatter field and do a bit better controll on chromaticle aberration.
Personaly I do not offer it as a high end scope, but as a nice widefield scope. In germany its far less expensive than a Skywatcher 102/500 douplet, espacily our chinese made version comes with rings, 50 mm finder, 2" diagonal and a Plössl eyepiece.
Its a good scope for low power wide observing and black and white imaging.
Today a german customer who got such a baby reported he used it also for Planets with good results
best wishes
Markus
clear skies
Markus Ludes
APM-Telescopes/Germany
