Williams optics problem
Started by bobblack, 02/04/2008 09:49PM
Posted 02/04/2008 09:49PM Opening Post
Hello all:- I have a w.o. megrez 80 II achromatic. the problem I'm having is when I put the scope on any angle but horizontal I can't control the focuser.
If I tighten the focuser lock screw, the tube won't move, If I loosen the knob the tube just slides right out to its maximum.There just isn't a sweet spotthat will allow me to control the focuser with the focuser knobs. It is a 1/10 microfocuser.
I'm thinking maybe I have lost a part. Has anyone had this problem???
Thanks, bob
Posted 02/04/2008 10:40PM #1
Thanks, bob
Normally one leaves the focuser lock loose. WO Scopes, at least my 2, have another adjustment located right over the focuser shaft. There is a knurled nut that holds the two speed in place and under it is a set screw that adjusts the preload on the shaft. That may just need adjustment.
I would just Email WO with your problem, in my experience they are very quick to respond. One time I emailed them Saturday night and Sunday morning I had an answer.
Posted 02/05/2008 02:25AM #2
Bob,
Check and see if there is a recessed Allen (hex) head screw right behind the focus lock knob. If so, that's probably the tension adjustment. Get an appropriate allen wrench and try turning that screw a quarter turn or so at a time and see if that makes a difference.
Jim
