I was out testing my scope for Telescope Pointing System Analysis (TPAS) last night.
Testing was performed on a Siebert 5.9mm Starsplitter for a friend.
I tested the Starsplitter against the 6mm Radian and 6mm UO HD Ortho and it did very well.
I will say that it is a good EP with eye relief and a FOV that is stated to be 65°. For $100 they are a good choice in that type EP.
The Radian is slightly better on through-put but has more color at the very edge.
The UO HD Ortho is identical to the Radian except for FOV being 45°-47° so a bit smaller and no color at the edge. The UO HD Orthos is $79.95 and is the best deal for the price of the 3 EPs.
The Radian is the best of the 3 by a hair, unless you take away points for the slight color at the edge, which I find to be a no big deal. This was because of the FOV and comfort more as well as the edge on contrast. The contrast on the Moon and Jupiter was even slightly better than the UO Ortho to my eye. Jupiter showed a little more detail in the bands with the Radian. The UO Ortho was so close though that it was almost a draw. But the narrow FOV and tighter Eye relief of the Ortho made it not the winner.
The Starsplitter has slightly less contrast on Jupiter, most of the details were there but just not as sharp due to the contrast I feel. It made the bands a little less bright and the festoons just did not pop out the same as the Radian or the UO Ortho.
The Starsplitter is a close second to the others. It has a good edge with no color but lack just a bit in the contrast and through-put compared to the other two. There was one other thing that I noticed when viewing Jupiter. When Jupiter was near the edge there was a scatter halo around the planet, it forms sort of rays too. Not terrible, but it was there. I felt it was more distracting than the color of the Radian. I also thought I saw a TINY bit of field curvature on the Moon. Very little and difficult to be certain so I will not make any real point of it.
Of the 3 EPs I preferred the Radian, just because it was more comfortable and had a slight edge on the Starsplitter.
The UO Ortho was overall a match in performance though and sharp with no color or curvature or scatter.
To rate the Starsplitter I will have to give it a good score. It performed well and the FOV was good and sharp. Contrast down slightly was not so apparent on DSO and it worked well to resolve clusters and show double stars. It was comfortable to use, light weight and easy to see with all the bare aluminum. Fit and finish was good and it came with a bolt case but no caps. Overall a good deal for $99 and a good performer. Compared t the price of the Radian you have to give the EP credit for it's performance level. Not a disappointment at all and rather a pleasant surprise.
