Best choice?
Started by RobertHowe, 08/26/2009 04:52AM
Posted 08/26/2009 04:52AM Opening Post
Any thoughts on the best EP for planetary viewing with a large apo? Something in the 5 to 8 mm range. I have a Nagler 9 which is awesome. An Ethos 8 gives too much FOV, it is distracting at this magnification.
Televue Radian?
Pentax?
Cheers
Robert Howe
Robert Howe
Wilbraham MA
TeleVue 85 f/7 // Astro-Physics Traveler 105 f/6 // Astro-Physics 130 f/8.35
Coronado 60 DS
"Scopes, Brains and Wisdom--but no Beauty"
Posted 08/26/2009 06:53AM #1
Robert
I really like the Orion 5mm Ultrascopic. It has the built in barlow and so provides nice eye relief and a good image right up to the edge of the field.
Steven Jindra
Posted 08/26/2009 05:58PM #2
Televue Radian?
Pentax?
Cheers
Robert Howe
Hi Robert,
I agree with you on the Ethos - no need for the hyper-wide FOV and it is quite distracting. And, definitely not the Radian unless you absolutely need the eye relief.
My daily driver eyepiece set is the Type 6 Naglers. These are very comfortable and do everything fairly well. However, a few years back I obtained a set of Takahashi LE's on a whim and have really enjoyed the views they have provided in my scopes which included an FS152, a TEC160ED and a 14.5" Starmaster.
The NT6's are sharp across the FOV, but the TAK LE's are more color neutral. The LE's are also VERY sharp on axis, very comfortable and seem to offer slightly better throughput then the more complex Naglers.
The TAK LE's are the best I've used for planets without getting into the boutique eyepieces like the TMB SuperMono, AP SPL, Ziess Abbe, Pentax SMC etc.
One final thought - if you like the 9mm Nagler T6, the 7mm and 5mm offer more of the same and get quite a bit of use in a Portaball-8.
