Ghost of Cassiopeia
big aperture newb, eyepiece list help?
Started by trdoug, 05/14/2006 01:59AM
Posted 05/14/2006 01:59AM Opening Post
I will soon be taking delivery of a dob made by James, Astrosky. smile smile smile I'm Doug T. on the bottom of his picture page. I think I would have been doing this some time ago had Ms. Rita "the hurricane" decided not to run over Jame's town. James has been pretty good at keeping up despite damages. Onto my question, I currently own an Orion 6" f4.9 and the switch to a 16" f5 means changes to our eyepiece list...i think. I'm hoping maybe some of you could weigh in on my list that I currently own and what I think I want?? I should add that we, me and my wife, are mostly into finding deep space stuff. We picked the ones to buy based on true fov we'll get in the new scope.
Thanks
Here goes:
What we have, and use regularly (all 1.25 barrel):
11mm televue plossl
26mm meade super plossl
2.5x televue barlow
What we think we want to add to the collection:
20mm nagler televue
32mm series 5000 plossl meade
50mm superview opt from oceanside photo & telescope
Outside maybe:
7mm nagler (1.25)
18mm series 5000 ultra wide (1.25)
32mm konig univ. optics
Posted 05/14/2006 02:45AM #1
Doug: Having had a 16" f/4.5 for almost 20 years, and being a deep-sky enthusiast also, I feel qualified to make a couple of recommendations for you. With the huge increase in aperture, you'll find that a number of deep-sky objects will bear much higher magnification than you got with your 6". An old "Type 1" Nagler 9mm gave breathtaking views of objects like the Ring Nebula, tight globular clusters and the like. You'll want something that powerful, with the widest possible AFOV. Alternatively, consider a Nagler 12mm T4. For wide field stuff like the Veil Nebula, M42, etc., I used a 32mm Erfle with a Lumicon O-III filter. Unforgettable views, even if the Erfle was a bit soft at the edges. If I had it to do today, I'd recommend a 31mm Nagler if you can afford it. For medium power views of objects like the Trifid Nebula, the Crab, etc., I had a 20mm Meade Research Grade Erfle, one of the finest EPs I've ever owned. Highly recommended with your fast 16". For maximum aesthetics on deep-sky objects, I recommend wide AFOV eyepieces - 65 degrees or more. Due to portability issues, I sold the 16" Newt and bought a C-14. It can't match the widefield views of the fast 16" Newt, tho. You're in for a real treat! Enjoy! - Chuck
Posted 05/14/2006 02:46AM #2
Congrats on the new scope!
Yes, the Hurricane really caused some real delays.
The 20-22mm Nagler would be perfect, the 32mm Meade 5000 SP I would not recommend, I owned it and I sold it due to soft edges and too big to fit the eye comfortably. Maybe a 35mm Panoptic would be a better choice.
The 7mm Nagler would be good or the 7mm Pentax XL but the 18mm UWA is too close to the 20mm Nagler, maybe a UWA 4000 14mm would be the better choice.
Posted 05/14/2006 03:04AM | Edited 05/14/2006 04:45AM #3
I don't think I'd want that 50mm at all. That's going to give a 10mm exit pupil in your scope. While it will waste a lot of light, that's not the main concern - with 16" of aperture one can afford to waste a bit on the really wide views. The thing is, there's a good to very good chance you will see the shadow of the secondary with such a large exit pupil. To be fair, people vary tremendously in this - but I certainly wouldn't buy anything that long without trying one in such a fast scope first.
Posted 05/14/2006 12:06PM #4
Doug
One thing no one is mentioning is an equitorial platform. The ability to track an object may significantly change your attitude about the usability of an ep, especially in your large Dob. After the platform I would then choose new EPs very carefully, and hopefully after you have had the chance to "try before you buy". Perchance you can mingle with a few who will allow you that opportunity. So far I have been through 17 eps in about a year and if I could do it over now the list would probably be about 5 real keepers, and not necessarily the ones that I currently have. It took me a long time to finally recognize even though I pretended to know all along that my needs would have been better served if I had waited and bought a Nagler or (fill in the blank) instead. As the thread indicates, a few well chosen EPs will be much more satisfying that a bunch of things you don't really need. Thank heavens for Astromart in that area. Good luck on you new scope; I hope to follow in your footsteps in a few months.
I Yam What I Yam!
