Cleaning EP's
Started by RUSTY845, 11/14/2005 03:55AM
Posted 11/14/2005 03:55AM Opening Post
Hi All; I'm new to all this ( about a year ) with 7 EP's now, I need to know the best way to clean them.
Thank's for all your help.
Bob
R.A.C. Advisory Committee
NEAIC Co-Chairman
NEAF Advisory Committee
Warwick, New York
41.15984 -74.2541
[B]Takahashi MT 160
10" F4.5 Newt 8O
R200SS grin
Some kind of 127mm APO
Orion Atlas EQ-G
Losmandy G11 with Gemini
iOptron Mimi Tower
iOptrom Cube Pro
Meade DSI PRO II 8O
SBIG ST-10ME
Image Source 21AU04.AS
Posted 11/14/2005 05:52AM #1
http://www.televue.com/engine/page.asp?ID=143
Posted 11/14/2005 03:05PM #2
Ok let me explain ... the scope and EP's are used by my 11 year old, she try's to be careful but sometimes hes little fingers get where they don't need to be so i'm ooking for a way to remove finger prints at home and in the feld.
Thank
Bob
NEAIC Co-Chairman
Warwick, New York
41.15984 -74.2541
[B]Takahashi MT 160
10" F4.5 Newt 8O
R200SS grin
Orion Atlas EQ-G
iOptron Mimi Tower
iOptrom Cube Pro
Meade DSI PRO II 8O
SBIG ST-10ME
Posted 11/14/2005 06:11PM #3
Well, so many things to comment about!
First, sorry, but I do not believe in the lens pen. Anything that you use more than once to me is not good. Use it and through it away! No contamination going from one EP to another.
Second, cleaning in the field should never be done, if the EP gets a finger, take it home an clean it. Of course this is easier to do if you have more than one EP with you. grin If you absolutely have to, then the first rule still applies, use once and through away materials only. You can blow the lens as clean as possible and use a Zeiss Cloth if you have to do so. But really not a good idea to do this often.
Third, cleaning with Zeiss Cloths I like, they work for me if I am at a site in the day time where I can see what I am doing or at home. Opti Wipes as recommended by Roland are very good with a little cleaner or alcohol.
Forth, Lens cloths of the type, Micro Fiber, or any other type like this, NO!. I have some here that I purchased. Professional use only and not available to the public. They still can get grit on them and scratch a lens! Again, use once and through away only materials. They are good for eyeglasses however and I use them all the time for that. wink
Posted 11/15/2005 01:24AM | Edited 11/15/2005 01:25AM #4
http://64.233.187.104/search?q=cachegrineeZE-cUe7AJ:www.arksky.org/asoclean.htm+cleaning+telescope+lenses&hl=en
Some similar and some different ideas on cleaning compared to
what TeleVue suggests.
