Howdy,
I've been rolling the same scenario over in my head for months now. I happen to have a 7" Maksutov, so we're dealing with two different scopes. Because I have a small aperture and long focal length, I didn't want a Barlow in the mix. However the 13mm Ethos works well, and the Antares Barlow is good. Astro Physics make one of the best if you want to make detailed comparisons. However, your 26mm Nagler and 13mm Ethos have you off to a great start.
I use a 56mm Meade 4000 series Super Plossl, a 27mm TeleVue Panoptic and a 13mm Ethos. In my scope the Ethos gives me a little over 200X. For higher magnifications, I've found the Takahashi LE series to be an excellent eyepiece. Better than the TeleVues for light throughput, color and contrast. I have a 7.5mm Tak-LE and am waiting for a 10mm LE.
When seeing conditions are poor, having a few extra small eyepieces comes in handy. Keep in mind these have a 52 degree aparent field of view, and wider fields are very useful on a Newtonian.
If you want to save some money and have heaps of aperture to begin with, the Barlow will work very well. Using an Ethos, a Nagler or any eyepiece with a Barlow reduces the True Field Of View (TFOV) in proportion to the increase in magnification, but you'll still have much more than other EPs will yield.
There's two cents!
Have a good one!
Steve
