james carter
North American Nebula NGC7000
Ethos vs. Nagler
Started by Larry Seguin, 01/30/2009 10:21PM
Posted 01/30/2009 10:21PM Opening Post
Has anyone had an opportunity to compare the 13 mm Ethos to the 17 mm Nagler? I'm thinking of trading my 17 for the Ethos, to be used in a 14" f/4.7 reflector, and an 8" f/6 reflector. The Ethos will be a sweet spot for both scopes and the field of view will be the same. Specifically, I'd like to know if the Ethos will be as sharp as the 17, and if there are any eye relief issues, as well as anything else you may have noticed! Thanks in advance for any insights you can offer!
Larry
Posted 01/30/2009 11:36PM #1
Larry
NO...but I have compared the Ethos 13 to the T6 13. Verdict? It was like going back to Plossls after Naglers first came out. No foolin'...
The E was dead sharp, sharper than the T6, I thought, the contrast was superior...and all that extra field? Huzzah!
LOL
Uncle Rod
Time on your hands?
Posted 01/31/2009 05:01PM #2
Not only is it sharp and has good eye relief, I think it's easier to center the eye on it and it's more comfortable to use.
My seeing, doesn't allow me to use the 13mm with a 16" f-12 Cass as much as I'd like, but with a Newtonian, you should be fine.
I'm looking forward to getting the 17mm Ethos. I wonder what the maximum focal length will be with that design..
Dan McConaughy
