Eyepiece Dew
Started by Peter Glus, 02/12/2011 04:23AM
Posted 02/12/2011 04:23AM Opening Post
I am getting frustrated with this issue. I'd rather not get the whole heater set-up, so I was thinking...is there anything wrong with just bringing the EPs in the house (warmer) and then taking them outside when viewing (in the outdoor observatory)?
Posted 02/12/2011 02:23PM #1
I keep my eyepieces inside. They fog up too easily if they are icy cold. I select the ones I am going to use and carry them outside in a small thermal lunch bag. If I am driving to a remote site, I will throw a couple of the chemical type of hand warmers into the kit when I get there. No wires, no heavy batteries.
I have never experienced any distracting thermal effects from a warm eyepiece.
dan
Posted 02/12/2011 03:50PM #2
Back in the day the AC adapter for my LX200 kept the dew off my 2 eyepieces when set up outside.
Since you have an observatory, try setting your oculars on an obsolete appliance thats plugged in: an old cable router, CRT monitor, VCR, etc. (no toasters!) Your eyepieces will stay warm and dry.
In the field I use a small box with chemical hand warmers on the bottom. I need one of those fancy eyepiece boxes that light up and have the heating element inside.
Good Luck
John
Posted 02/12/2011 05:38PM #3
As long as they don't dew up from being brought into the warm, from the cold.
FWIW, I store the ep's at ambient, bottled and in a closed case with some small desiccant packets tossed in (with other astro stuff too).
But when at the focuser I keep them in specific eyepiece only pockets on me.
Body heat keeps them dew free, and will un-dew those that have been in the focuser long enough to dew (or frost).
I have -astro only- warm and cold weather pocketed outer wear.
Some folks use photograghers vests or fishing vests to success.
Posted 02/12/2011 07:34PM #4
They'll fog right up then. Best bet? Keep an eyepiece you are not using in a pocket. Usually, if you dew is not too bad the heat from your eye will keep the one in use clear. Dewheaters really are a far better and less annoying solution. If you are on a budget, get one of the little 12vdc hair-driers/dew zappers.
Uncle Rod
Time on your hands?
Posted 02/12/2011 09:54PM #5
I use the disposable heat packs, specifically "Hot Hands" (Made in the good ole U.S.of A!) in my coat pockets. From my experience, this brand lasts longer than others that I have tried. Also, if you are done observing they can be placed into an airtight ZipLock bag and used again at a later time. They are air-activated. I can usually get 6-8 hours out of them. In a pinch the heat packs can be attached around your eyepiece with a rubber band. Low tech wins!!
