GSO 2" Barlow
Started by streets, 08/06/2006 12:24PM
Posted 08/06/2006 12:24PM Opening Post
I just received mine from Owl Services yesterday. If there is a better buy in a 2", 2X Barlow for $49.00 I'd like to hear about it. Using this thing is, simply put, doubling the power of an eyepiece with absolutely no degredation of image----period! It also works as a 3X if placed in front of the diagonal, again with wonderful results. Comes with a 1.25" eyepiece adapter. It's well made and light weight and, like the GSO 2" 42mm eyepiece, one of the all time great bargains in astronomy equipment.
Posted 08/06/2006 06:21PM #1
You can also remove the lens element from the GSO barlow and screw it directly into a number of 2" eyepieces. I have tried it with the RPD 30mm 80 degree eyepiece and others. It doesn't work so well if you are using a refractor with a diagonal but it worked great on a Newt.
clear skies,
dan
