For high power viewing with my TV102 I have a 7.5mm Sirius Plossl and a 6.4 Meade Plossl. I was thinking of getting an Abbe Orthoscopic in the 4mm range, but I have been finding that it is uncomfortable looking through such a small aperture eyepiece. Therefore I am saving my money for a “premium” 4mm or 5mm eyepiece. Considering the price of a Nagler as being the most I can afford, what other brands would you recommend?
High Power Eyepiece Recommendation
Started by davidcolton, 06/10/2005 01:52PM
Posted 06/10/2005 01:52PM
Opening Post
Posted 06/10/2005 02:52PM
| Edited 06/10/2005 03:28PM
#1
Hello there Fella TV-102 David,
In addition to the excellent 5mm NT6, I would also highly recommend 5mm and 4mm Radian for your TV-102. When Mars gets bigger later this year and if you get excellent seeing from time to time, you may wish to consider the 3mm Radian as well. The TV-102 at 293x on Mars in very good seeing is a wonderous sight. BTW, I've compared my 5mm NT6 and 5mm Radian and other than the obvious eyerelief, AFOV and lateral color difference, I couldn't find anything I could see in one that I couldn't see in the other, nor contrast, nor brightness differences.
Alternatively, you may want to consider the 3-6mm Nagler zoom. Although the eye relief of 10mm is a little uncomfortable to me (which is still far better than the 4mm ortho), I can pull back a little bit for a comfortable view (sacrificing only a bit of the AFOV).
Best wishes to your quest.
Ron the 4-inch Tall Evangelist B[ee]
Posted 06/10/2005 02:59PM
#2
Hi David,
I've had good luck using a 5mm TAK LE with my TV102. Sharp, reasonable field of view and very good eye relief. Not too expensive, either, when compared to some others.
If you can find one, a 5.2mm Pentax XL would probably be excellent. I don't have one (yet) but the 7mm and 10mm XLs I do have are my favorites. Have not tried the Pentax XWs yet but they're supposed to be even better than the XLs...they should be, they cost alot more.
I have virtually no experience with Naglers or Radians; but am familiar with the short f.l. Sirius Plossls and U.O. Orthos. The Tak LE is a big improvement over both; comfortable while still very sharp.
FWIW
Bob
FWIW
Bob
Posted 06/14/2005 10:44PM
#4
Has anyone tried the Tele Vue High Magnification Zooms? I have the 2-4mm zoom on a Tele Vue 60 and it works quite well. Although expensive, the zoom feature precludes having to get 2 or 3 other fixed magnification eyepieces to cover that range?
Rey Cordero
Berkeley, CA
Rey Cordero
Berkeley, CA
Funding Member
Sponsors
- CarbonScopeTubes LLC
- Anacortes Telescope
- FocusKnobs
- Matsumoto Company
- BBLABS LLC
- Astromart Customer Service
- Vernonscope
- APM-Telescopes
- OMI OPTICS USA LLC
- Waite Research
- SellTelescopes.com
- astronomy-shoppe
- kwtelescope
- RemoteSkies.net
- BW
- Desert Sky Astro Products
- AstroMart LLC
View all sponsors
