I have disassembled a few orthos to blacken the edges for better contrast. It did make a noticeable difference. I have an older Park 25mm Plossl (non gs) that has some sort of debris in between the elements. I would like to disassemble it. The orthos really were no problem mainly because there was just a spacer in between the two elements . My question is, with four total elements in two groups of two, are these groups of two, cemented with a spacer in between the two groups, or are all four elements separated by spacers. From the diagrams I have seen it looks like they are cemented together in two groups and separated by one spacer.
I just wanted to know what to expect, after unscrewing the retainer ring and start removing the elements.
I am aware that it is not advised to attempt to disassemble an eyepiece. I am doing this as a "can I do it project" It is not worth it to send it to the factory. Whatever is in between the elements (mold) makes the eyepiece pretty much useless, so nothing to loose and perhaps a little knowledge to gain...
