In the used section of Amart I often see ads for "matched pairs" of eyepieces for binoviewing. Is there a method for "matching eyepieces" for binoviewing or is this like "semi-apo" where people use the term, but it is essentially meaningless.
Matched Eyepieces for Binoviewing?
Started by mte1955, 06/07/2009 02:10PM
Posted 06/07/2009 02:10PM
Opening Post
Posted 06/07/2009 11:22PM
#1
Michael,
I have used a binoviewer for almost 10 years now, and I do not plan to go back to a single eyepiece view. It's a great way to observe the heavens.
Have you ever looked through a pair of binoculars and the field of view seemed to overlap or be out of collimation?
Indexed or matched eyepieces do make a difference when observing.. I have seen field stop diameter differences in the past, which in my eyes makes the binoviewer itself appear slightly out of collimation.
The way I determine if two eyepieces have identical field stop sizes is to place the moon in the FOV, and slew the view on a driven mount (I use an AP1200) to show a prominent crater in the FOV (half in and half out) at say the three o'clock position.
If you look through the right side eyepiece only, the crater should maintain that position, then look through the left side eyepiece and the same should be true. Many times, the crater will be shifted slightly in the view from one eyepiece to another..If the view is good at the three o'clock position, I also repeat this check at the 6, 9 and 12 o'clock positions as well.
It is my experience that perfectly aligned and matched field stops will show no changes in the view when placing a crater half in / half out.. whether the positioning at the 3, 6, 9 and 12 o'clock positions.. or anywhere else in between.
I have also found that simply rotating one eyepiece or the other while viewing with both eyes will assist in the process of matching or finding that sweet spot..
Mark Clegg
Mark Clegg
Posted 06/08/2009 11:36AM
#2
I wouldn't worry about it too much. I use no-name/store brand Plossls frequently in my Denks, and they work just fine. Get a pair where there is a large difference in focal length or eye relief of AFOV, and you could have trouble, but it is not at all necessary to use hand/cherry picked expensive pairs.
Uncle Rod
Time on your hands?
Funding Member
Sponsors
- BW
- AstroMart LLC
- kwtelescope
- BBLABS LLC
- Desert Sky Astro Products
- Waite Research
- Matsumoto Company
- Vernonscope
- Astromart Customer Service
- OMI OPTICS USA LLC
- CarbonScopeTubes LLC
- FocusKnobs
- APM-Telescopes
- astronomy-shoppe
- Anacortes Telescope
- SellTelescopes.com
- RemoteSkies.net
View all sponsors
