Anyone have any experience or seen any reviews on these yet? I'm contemplating what to pursue for my astigmatism laden eyes, and thought these new eyepieces might fit into the mix. Also, can someone remind me how to calculate actual field of view. I'm using a 6" f/8 (focal length 1200mm). Thanks.
Orion Stratus
Started by DaveKG, 04/15/2005 06:25PM
Posted 04/15/2005 06:25PM
Opening Post
Posted 04/15/2005 11:09PM
#1
The rough rule of thumb is True FOV = Apparent FOV/ Mag
Take a 22mm Epic with 55 degree stated field of view. In your scope, it would yield 55x as the magnification. 55 degree/55x = 1 degree field of view on the sky. Or, let's do a 15mm standard Plossl, with 50 degree fov. It yields 80x magnification, or, with 50/80, .63 degree fov at the scope.
The purists and technical gurus will inform you that this is only an approximation and that the real field of view involves field stops, etc. but this should give you a ball park figure. Note: it can be off 5%, 10%, or 15%, partly because of the technical stuff, but also because, sometimes, manufacturers' stated fields of view are wrong, often too high! (In some rare cases, they've understated them!)
I have astigmatism, too, and means that I must observe with eyeglasses on for low power views to look good. Eyepieces with 20mm eye relief are recommended for eyeglass wearers (such as the Epics, Radians), but one can tolerate more or less e.r. depending on the thickness of one's glasses and how close they are to their eyes. 25mm+ Plossls or Ultimas (excellent line) have sufficient eye relief. One can barlow those to achieve higher powers, or get a mid-range Epic or X-Cel, and then at high power, one can remove their glasses and use most any eyepiece, or go for something more $$, say a Radian.
I particularly like an 8-24mm zoom as the eye relief is fine, it covers a wide range of magnifications, and the contrast, views match those of good Plossls.
Funding Member
Sponsors
- kwtelescope
- astronomy-shoppe
- Waite Research
- BBLABS LLC
- APM-Telescopes
- Astromart Customer Service
- Matsumoto Company
- RemoteSkies.net
- Desert Sky Astro Products
- Vernonscope
- CarbonScopeTubes LLC
- BW
- FocusKnobs
- SellTelescopes.com
- Anacortes Telescope
- AstroMart LLC
View all sponsors
