Wizard Nebula
Re: 102 f/10 refractor
Started by Bob Chester, 02/11/2005 05:21AM
Posted 02/11/2005 05:21AM Opening Post
Mark,
The TV 32mm plössl provides the largest true fov in a 1-1/4" eyepiece. To get a larger true fov you would need to move to a 2" eyepiece.
The TV 24mm panoptic provides the same true fov as the 32mm but with higher mag and a little darker sky background and is also 1-1/4".
If you don't have a 2" focuser either eyepiece would be a good scanner.
Bob
Fujinon 10x70 FMT-SX binocs
Tak FS-78 ƒ/8.1 - 630mm fl.
