Iris Nebula
Review on 32mm. ERFLE
Started by Midnight Sun, 09/11/2008 03:23PM
Posted 09/11/2008 03:23PM Opening Post
Has anyone seen/read any reviews on Celestron's 32mm. 1.25" Erfle ep? I have heard good reports when this optic is mentioned...would appreciate any feedback or actual "hands on" tests.. thanks, John M
Posted 09/11/2008 03:51PM #1
I don't have any first hand information with this particular eyepiece, only the Celestron 20mm Erfle. Just point out that when considering the performance of any Erfle, the focal ratio of the scope is critical... So what telescopes are you hoping to use it in?
Posted 09/11/2008 04:58PM #2
Scott, yes it is the older one, glass looks gorgeous! waiting for it to arrive in the mail. What kind of scope do you have? Jon in the thread above mentions that type of scope is critical.. JM
Posted 09/11/2008 06:35PM #3
Does anyone know if there is an advantage over the 32 mm Plossl design? I believe both the erfle and plossl will provide the maximum FOV in a 1.25" eyepiece.
Posted 09/13/2008 03:48PM #4
Hi John,
I bought on recently to use in a Cave 8" F/8 scope. A few days ago I dropped it into the diagonal of an FS-78 with an extender Q in place. At F/12.8 it was sharp right to the edge. At F/8 it is pretty much the same with a very slight fall off over at the edge of the field. I might not have noticed it if I had not been looking for it.
Larry
Posted 09/26/2008 07:27PM #5
*****I sold one of these, but I regret it now. It was super sharp with pinpoint stars all the way to the edge of the narrow field in an f/10 SCT. I was impressed. The AFOV is narrow, though, for an Erfle - I estimated 45deg. IN shorter f-ratios it acted as other Erfles = bad coma and astigmatism made it worthless. So, actually, since I have no long f-ratio scopes it was OK to sell it.
-Jason A.
Scott Mortimer said:
John - Do you mean the old one? I have one, it's a nice eyepiece. It gives near the maximum fov in 1.25 inch eyepieces, I think the AFOV is around 50 or just below. I kept this because it seems like good quality glass, nice dark background sky, nice white-neutral colors. Made in Japan. This was a nice line of eyepieces that is probably better than a lot of today's lower-priced options.
-Scott
PS, as Jon says these work better at long f/ratio. At f/15 I thought this was at least as good as a 30mm Tak LE. At f/8 the Tak LE would be better.
