Ghost of Cassiopeia
Starmaster 14.5 binoviewer eyepieces
Started by gladiataar, 02/22/2006 08:22PM
Posted 02/22/2006 08:22PM Opening Post
This question is somewhat directed toward Floyd, because I know he has a Starmaster 14.5, but anyone with a fast dob or other advice, please chime in...
I have my first deep sky telescope on the way and am looking for some mid-to-upper-range eyepiece advice. I plan on using a Denk II binoviewer for virtually ALL viewing sessions, and with my current OCS/Power X Switch configuration, I'll get 1.4X, 2.25X, and 3.5X magnifications. I am aware of an available lower power Newtonian Power X Switch, but plan on using the binos with a refractor as well, and don't feel like swapping out Power X Switches all the time, so I'll just stick with the higher power Refractor Power X Switch and deal with the slightly higer magnification in the dob. In addition, I'd like to use the 2.25X setting most of the time because it has the lesser amount of glass/air surfaces in the light path.
So...keeping in mind any eyepiece recommendations will be magnified 2.25X, what's a good mid-to-upper-range deep sky eyepiece pair for a fast 14.5" f/4.3 dob? I already have a pair of Pan 24's that bring me up to 149X. Will the Nagler 16mm T5 be too much magnification (223X) for deep sky here in New England? What about its eye relief? I've heard nasty stories about people not being able to use the full 82 degree FOV because of it. I don't wear glasses. What about the Pan 15? Same eye relief problem, or so I've read, but maybe the 68 degree FOV would be plenty in the binos, and it's a lot cheaper. If these focal lengths are too powerful for regular use, would the Pan 19 (188X) be a better choice for deep sky? What about other choices in the 16-19mm range with wide fields that are good in binos?
I have plenty of eyepieces for the planets, so that's not an issue, and price is of no object.
Ken
Posted 02/23/2006 01:21AM #1
I would think the 24mm Panoptics would be absolutely optimal. I have used them in a Denk II and it was fabulous.
It would seem to me you would want about a 14mm for 250x, so maybe a couple of 15mm TV plossls? I have those and they are pretty nice. Not too wide, but very crisp. Or 14mm Radians would be nice, but I have not had the chance to try them on a Bino.
Honestly, I am just starting out in Binoviewing and have much to learn myself. smile
I have used 3.5X on the 15mm TV Plossls and have like the view. So 5mm is possible. But most nights I would think that 250-300x will be optimal.
Floyd
Posted 02/23/2006 03:13AM #2
I also have a 14.5" Starmaster that I use with the Denk II binos and power switch. I very seldom use anything but the 24 Panoptics.
Posted 02/23/2006 04:39AM #3
Thanks everyone for the great advice!
Jim, you have an interesting point regarding monoviewing. I'll have to re-visit that line of thinking. I've just enjoyed my binoviewers so much, it's hard to go back to the cycloptic world, but you are absolutely right when it comes to wide angle viewing. The Pan 35 was actually the last eyepiece I gave up when switching over to the binos--that was tough.
I have a set of 15, 12, and 8mm Edmund RKE pairs for the planets, and love them, but their FOV is a bit restrictive for anything else. Floyd, I'm a little surprised you find 200-300X to be an optimal range for this scope. Are you referring to deep sky or planets?
I've heard great things about the Radian line, but don't care too much for that eye position adjust mechanism, and they only have a 60 FOV. Several commented on the 19 Pan. I'm strongly considering that one. I guess I'm trying to find out if 225X (16mm) is going to be too much magnification for typical deep sky viewing with this scope? If so, through the advice I'm hearing, I'll probably just stick with the 24 Pans for now.
Ken
