Tele Vue 10mm Raidian is Binos ?????
Started by peteschuerhoff, 01/01/2005 05:10AM
Posted 01/01/2005 05:10AM Opening Post
I've some negative general discussion in the use of 2 10mm Radial in a bino configration. Doe's anyone has the same experice with this ep? :S
Posted 01/01/2005 11:50AM | Edited 01/05/2005 11:58PM #1
Peter,
I've used both 18 and 14 sets! They were the sets I minimized to after using many. I still retain the 14's but opted for 19 Pans for ever so slightly wider field. On my TMB 115 and TEC 140, they had superior contrast and sharpness to Meade 24.5 SWA, the Pans and Nagler 16. You must have the interocular distance perfect, and the click stop correct as well, but I sure like mine.
Mike
Posted 01/01/2005 11:42PM #2
Thanks to all of you in regard to my question. I certainly helps in the decision process.
Pete
Posted 01/16/2005 03:41AM #3
Thanks to all of you that have responded to my question. It gives me some idea of the general range of eps preferred.
Regards,
smile Pete
