Gary Taylor
M27 - Dumbell Nebula
There is no competition for Speers Waler WAs
Started by 152ED, 05/23/2006 06:16AM
Posted 05/23/2006 06:16AM Opening Post
Lets face it there are a ton of eyepiece choices these days, and three main types of scopes with a range of focal ratios. A bewildering array of brand names and designs has become available to amateurs in recent times and one of my favorite designs for f/8+ scopes, the Widescan, has finally become more available / affordable. Sadly, faster scopes make a mess of simple classics such as these.
Long story short: nothing compares to the latest Speers Waler line (the WA series) for field sharpness over 80+ degrees in f/5ish scopes in the under $100 price range. They are a cross between naglers, meade uwas, with a healthy dose of propriety thanks to the tenacity of Glen Speers up in Canada who designed them. The optical configuration is a negative / positive group such as the Type I nagler, which allows much more opportunity for correcting astigmatism and coma. You simply can't buy any other genuine negative / positive lens group eyepieces for $90 on the used market, and this design element is the hallmark of full field sharpness over 80+ degrees in f/5ish scopes.
I've had eyepiece fever and owned a few scopes, basically one of each main type other than maksutovs. Nothing changes the eyepiece more than the scope! Good eyepieces in my C102 were so-so in my 152ED and 12 SCT, and downright horrible in a 6" f/5 skyview deluxe Orion eq newtonian. Speers Waler or other UWA style negative / positive lens group eyepieces can deal with any scope and give respectably sharp images over the whole field.
The only exception to this rule is the 18mm SW which is a low cost compromise, in that a true scaled up 10mm SW would be way too large (the old type I nagler syndrome). Even so, in my current f/5 Celestron 8" newt, even the 18mm SW gives 70 degrees of near panopticesque sharpness with eye relief good enough to wear glasses. The additional 10 degrees is there for dramatic effect basically, but the full view is quite satisfying.
It's cloudy tonight and I've got another oddball eyepiece to test (TAL 24) so out of sheer boredem, I thought I'd tell you all that you won't find a sharper ~$100 wide angle eyepice for your f/5ish newtonians than the Speers Waler WA line. Now I've got my set pretty much collected so I can write this, ha. smile I'm surprised they stay on the used market for so long, they are definately the best bang for buck eyepiece for cheap yet large scopes.
Posted 05/23/2006 10:31PM #1
I'd agree with you given your perameters. For a little over $100., considering it's 80+ degrees AFOV, it doesn't have too much competition.
No, it's not a Pentax or Nagler. And I'd agree the TMB/Burgess planetaries are superior, but they have a substantially more narrow FOV.
My experiences have been with the longer focal lengths, though.
